How to remove CA hinges?
Building my LT-40, seems I have the hinge-gap set too narrow. I can't quite get my 3/8" travel like I want, so does anyone have any suggestions on how to remove c/a hinges? Besides using a razorblade?
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: exeter_acres
Well...at least we hope so while the plane is flying!
ORIGINAL: MinnFlyer
Yep, once they are in, they're IN
What I was afraid of.
Since I don't have as much throw in the ailerons as I'd like, I am thinking of leaving the c/a hinges in and attaching clear packing tape over the hinge gap, in an attempt to at least make the existing hinges more efficient.
Think that might work?
My Feedback: (9)
Sealing the gaps won't give you any more throw, but they will definately improve performance. It's not really hard to cut and rehinge the surface, it just takes a little bit of time. If you don't have enough throw then you might want to remove surface and reshape it so you have more throw.
Hope this helps.
Hope this helps.
ORIGINAL: RCKen
Hope this helps.
Hope this helps.
I'm sure the re-hinging is do-able, just sounds like a royal pain, since the wing is covered and I'd prefer not to de-cover it. So if it comes down to it, I'll use hinge points and not c/a hinges.
Of course, this is a trainer, so I don't need a huge amount of control surface performance. Not like it will be doing a lot of axial rolls.
My Feedback: (36)
MT
I cut them flush with the control surface and TE, and then use the Great Planes Electric Hinge Cutter. Put the blades right in the center of the old hinge, and put the hammer down, it works nice. I replace them with the thicker Du-bro pinned style hinges, so it works good even if the hinge slot is a bit larger due to cutting through the old hinge. New CA Style go right back in too, and work good again. Little buggers stay in there real good.
Good Luck.
If you want to use hinge points, just drill them out, will work just fine even with the plane covered, wouldn't take long at all.
Good Luck.If you want to use hinge points, just drill them out, will work just fine even with the plane covered, wouldn't take long at all.
My Feedback: (9)
ORIGINAL: BigSkyRCer
MO
Before you go ahead and cut out your hinges check something first flex your control surface and find out where your alerion is interfering. It it may be in just 1 or 2 places (due to you bevel not being straight) if thats the case you won't have to remove your hinges just remove a litte more mat'l from that area,
