Engine Thrust angles on low wing planes
MO
I am getting ready to build the fuselage on my Great Planes P-51D Mustang the plans call for 2 degrees of right thrust. While I am planning to build it per plan this seems extreme for a low wing plane. I though wing location was the major factor in determining thrust angles what other factors determine the starting thrust angle for a particular airplane? Although I am not expert this my 6th or 7th kit based on my previous experience thrust angles should be for:
High wing planes:
2 degrees right thrust
Mid wing planes:
straight ahead
Low wing planes
straight ahead or 1 degree down
High wing planes:
Mid wing planes:
straight ahead
Low wing planes
RE: Engine Thrust angles on low wing planes
Thrust angles are not dependent upon the location of the wing, but how the designer wants the model to handle. All of the relationships in the model, such as areas, moments, weights, and so on dictate the exact design specifics. That includes the position of hte engine.
A thrust angle in the engine is there only to reduce or eliminate trim changes when the power changes. In the case of the Great Planes P-51 40-size, the right thrust was found to be needed to help reduce the left-pulling tendencies. If you build the model dead-stock, it will give you the flight characteristics that are advertised.
