Needle setting on an Evolution 100 engine
CA
I took out the needle on my Evolution engine to fit the cowl onto my FUntana90. I forgot to count the turns before doing so. There is no mention in the maual on how many turns to start with as the Set Right needle is preset at teh factory. Any help with this?
Screw it all the way in, NOT Tight, Just till you feel it stop. Then 3 complete turns out...Start there and it will probaly be on the rich side, but you will be able to set the high end from there. Hope this helps.
