change engine position
My Feedback: (42)
Can you change engine position( vertical to horizontal, horizontal to inverted) with out affecting the plane. Ihave a piper cherokee with a Saito 50 mounted horizontally I want to mount inverted so the engine want hang out the side of the cowl
My Feedback: (24)
ORIGINAL: dixie flyer
Dont forget, you may need to lower the tank if you invert the motor. The center line of the tank needs to be between 3/8" below, to even with the spraybar in the carb.
Inverted engines often act like they have a terminal case of PMS. It is so bad they are going to die from it.
Bill
