 my first EDF jet >
my first EDF jet
my first EDF jet
Old 04-11-2006 | 10:31 PM
Default my first EDF jet
I'm planning on building an EDF F-16 and here are the estimated specifications:
wing area: ~140 sq.in.
motor: speed 400(around 10 oz thrust)
weight: 16-18 oz.
Is there anything wrong with the specs. ? should I go for it, or should I increase the wing area or is it okay? I might prolly change to brushless.
Old 04-12-2006 | 06:38 AM
firstplaceaviator's Avatar
My Feedback: (27)
Default RE: my first EDF jet
I would increase wing area to at least 180 sq. in.
Use a brushless motor to start with. Brushed mototrs in ducted fans usaually don't last more than a few flights.
I recommend a Model Motors "Mini AC" 1215/12 12 or a MPJet AC 25/25-26 Mk. 2
Don't even consider Ni-cad or Ni-Mh batteries. Use only Li-Po's. a Thunder Power 3 Cell 1320 Mah battery will be perfect.
Keep us posted on your progress!
Doug
Old 04-12-2006 | 07:11 AM
Thanks Doug. I had the same idea, increasing the wing area to 180 sq. in. because I noticed most ARF 400 size EDF Jets have around the same wing area. Anyway, I'm just planning on the materials and power system for the F-16 I'll probably start making it in 3 more weeks. I will post my progress here.
I was wondering how to exactly calculate the wing area. The 140 sq. in. was measured from 2 trapeziums on the sides and one rectangle in the middle, or should I measure it as a triangle at the top and a rectangle at the bottom ?
I used the first picture to calculate the wing area, is taht right ?
Thank you.
matt
Old 04-12-2006 | 09:51 AM
My Feedback: (27)
Matt,
Manufacturers use several methods for calculating wing area.
Some even include the wing center section (through the fuselage) in their calculations!
I ususally subtract the fuselage out. Full scale engineers don't include the fuselage as wing area.
But, becuase the shape of the F-16, the fuselage does provide quite a bit of lift.
So, your 1st diagram and calculations will work just fine.
My Byron F-16 is very difficult to stall becuase of the shape. It just goes into a nose high attitude and starts loosing altitude quickly!
Just add a bit of throttle, and it flies beautifully in high alpha.
For me, it is easiest to calculate a rectangle, then subtract out the triangular portions.
Old 04-13-2006 | 11:28 AM
Thanks again Doug, that really helped. I've already modified my sketch to fit the new wingspan. I'll probably start cutting some white foams soon, screw that 3 weeks .
Old 04-14-2006 | 10:59 AM
As promised here are the pictures of 2 days progress:
The white foam with this model really requires ALOT of sand papering. The dimensions aren't as exact as the full scale, the middle platform was taken from here http://www.rcgroups.com/forums/showthread.php?t=337663 . I had to add some wingspan to get the 180sq in wing area. For me as long as it "has" the shape of the real F-16, it should be ok . Anyway I have to wait for another 2 weeks before I start on the back and the ducting parts because I'll need to get the ducted fan system first.
Old 04-14-2006 | 12:05 PM
My Feedback: (27)
Lookin Good Matt!
If I didn't already have WAY TOO MANY planes, I'd ask you to build me one too!
Old 04-14-2006 | 11:50 PM
TOO MANY ??? How many is that ? I've never built a plane for anyone before maybe it's because there are not many who likes RC airplanes at my place. I've always thought about selling some too, but I think I'll do that after I get out of college. However, recently a friend of mine just started to be interested in RC modelling after watching me building that F-16. Suprisingly he has already started on his own model, a Euro Fighter EDF.
Old 04-15-2006 | 07:45 AM
My Feedback: (27)
Well, for me 23 RTF planes, 4 helis and 114 kits is too many. I'm out of room...Time to liquidate again!!!!!!!!
When I was in college, I only had one 42% Scale Extra 300, a Goldberg Extra 300, a Lanier 1/4 scale Laser 200, a Yardstick and about 3 kits!
I've been out of college for 10 years now. Most of the model stuff I have has been purchased since I got married and bought a house in 1999. Oh yeah, did I mention the full scale Cherokee?
Doug
