Pusher Props
CA
Does anyone know of any company that produces a good selection of 2 and 3 bladed PUSHER props? I know Zinger makes a few, so does Master Airscrew and Graupner. Grish makes a few too but Im not sure if they are even in business any longer. Im looking for an 8x7 2 bl. or a 7x7 three bl or there abouts. Higher pitch is best, so smaller diameter is required. Nothing bigger than an 8 inch prop will fit.
Any info is appreciated.
Chuck
Chuck
CA
It was simply a ground clearance issue. I found an APC 9x6 2 blade pusher and it works fine but after a couple landings it has now been trimmed down to about 8"!
Charles
Charles
I use a 9x6 APC prop on my pusher/puller and it has lasted about 4 years so far. I fly on grass. Are you on a hard surface like concrete? You may need taller landing gear.
