the best
hi....
I would like to know what will be better of it. I am thinking in a 1.80 metres airplane with 25 cc gas engine approximately.....
Suggestions????
Thanks.....
Suggestions????
Thanks.....
For a 1.8 m wing-span aircraft I would use a glow engine instead of a gasoline engine.
I can recommend the OS 160FX and the Moki 1.80 or 2.10 engines, all have awsome power to weight ratio and are readily available in Europe. For four-stroke engines the Saito 1.80 or 2.2 comes to mind. Another alternative is the YS160-DZ, that engine however needs at least 20% nitro making it expensive to run in Europe, where nitro is very expensive.
There are a ton of aircraft available in the 1.8 m range. Most ARFs in that size range are for aerobatics. Do a web search. Some Europen brands that should be available to you are:
Graupner Laser 200,
Protech Staudacher S600, Giles 202 or Extra 300,
Hacker CAP 232,
JR Models Cap 232 or Diablotin 2000,
the list goes ever on...
/Red B.
Graupner Laser 200,
Hacker CAP 232,
/Red B.
With aircraft this size what you will most likely experience if you go gas is low power, high weight and a lot of vibrations ;-).
Most of the 1.8 m aircraft available are designed with glow engines in mind.
Gas engines are much better suited for bigger aircraft.
/Red B.
/Red B.
ORIGINAL: weporion
in your opinion, what size will be the best for my first gas's airplane?
/Red B.
