Throw measurement on tapered control surfaces
When measuring a control surface deflection (throw) do you measure at the tip or root on a tapered surface? If measuring degrees then it doesn't matter, but most manuals reference inches of deflection. Thanks.
My Feedback: (10)
RE: Throw measurement on tapered control surfaces
surf,
What I normally do is hold a ruler vertical to the TE of the control surface and then move the stick both ways and adjust everything machanically as close as I can get it and then If it needs a little tweaking I use my end point adjustment. You don't have to be exact on the measurements, just get it close and once your in the air you'll know if you need a little more or a little less and once you land you can use your end point adjustment again. Don't forget to set your Expo.
ORIGINAL: Stew99
On the one's I've had, the deflection is measured at the widest part of the control surface.
So widest part of the surface (typically the fus end). I know it doesn't matter that much as you will adjust throw to your liking, but I always like to start where the manufacture recommends. Thanks for the replys.
