CG G.P Tracer
My Feedback: (12)
CG G.P Tracer
I have just flew my new GP Tracer today and I have to say it flew great except one problem!! when I tried to do a loop, the more i pulled elevator into it the plane left the loop and did like a corkscrew, is the a CG problem or a mis adjusted elevator problem?
could be Either......
Check the CG tail heavy condition can cause that, Also check your elevator throws and deflection to make sure they are the same. I think the tracer uses a dual pushrod set up, also check to make sure the linkage rod on 1 side is not flexing under load.
Should be a easy fix, good luck,
John
John
