Pull Pull System >
Pull Pull System
Pull Pull System
Old 02-17-2002 | 02:54 PM
FCC
Default Pull Pull System
What is this pull pull system... and where it is used?
Old 02-17-2002 | 03:38 PM
Scorpionjack's Avatar
Default Pull Pull
FCC;
Pull pull systems are primarily used on Rudder, but can be used on any surface. So it's not isolated to any given area of the Aircraft.
It is a positive feedback system as there is no slop and you can get tremendous throws from a Pull pull system.
there is different methods of setting up a Pull Pull system the one I'll show you is common. But there is others that we use in Larger scale aircraft to alleviate the constant shock on the rudder/Servo. That is using a bellcrank system then hooking the servo to the bellcrank. allowing the bellcrank to absorb majority of the shock.
Old 02-17-2002 | 03:39 PM
Default Pull Pull common servo hook-up
Here is a servo hook up fairly common
