 cox engine 0.49? >
cox engine 0.49?
cox engine 0.49?
Old 04-15-2007 | 06:05 PM
Default cox engine 0.49?
i have a cox engine0.49 modle, but do not know the needle setting for the carb.
Old 04-15-2007 | 06:10 PM
Default RE: cox engine 0.49?
why?
Old 04-15-2007 | 06:50 PM
carrellh's Avatar
It has been around 35 years since I started a Cox .049 on a plastic control line plane
I think they called for opening the needle 3 turns for initial startup.
If it just burns the prime and dies; close the needle 1/8 to 1/4 turn, re-prime, and try again
Old 04-15-2007 | 07:22 PM
if it is just burning the prime it's not getting fuel so the needle valve should be opened.but I believe youre correct about the 3 turns open,that is usually the starting point for reed valve engines.
Old 04-16-2007 | 07:50 AM
thanks guys
Old 04-16-2007 | 08:47 AM
how do you prime the engine?
Old 04-16-2007 | 10:46 AM
squirt a few drops in the exhausr ports when they are open
Old 04-16-2007 | 11:16 AM
i got the engine running but will only stay running for a cuple of seconds, its differnt from a t-maxx truck. dos it need a backpresser line
Old 04-16-2007 | 11:58 AM
anyone. it wont stay running why? the little tube behind the needle what is it for?
Old 04-16-2007 | 01:32 PM
can you post a picture of the engine,if it doesn't stay running but revs up in max rpm before stopping it is not getting any fuel from the tank open the needle valve 1/2 turn and try again,once it starts and stays running you adjust the needle valve till you get near max rpm.
Old 04-16-2007 | 03:41 PM
her it is i got it running for a min/two, how do you tell when the piston/sleeve is bad? do you know any outher modles i can put this engine in ?
Old 04-16-2007 | 03:45 PM
i only have the engine. what temps should it be running aruond should it smoke it is a two-stroke. i used traxxas 20% top-fuel in it i know its not right but it runs it is a two-stroke
Old 04-16-2007 | 03:46 PM
how big is the tank?the tube behind the needle goes to the tank.is this in a cox plane or what?usually they only have a tank big enough to run 2-3 minutes
Old 04-16-2007 | 03:48 PM
its not the stock tank. the tank is prettty big its a two oz tank. yas it is a cox 0.49 killer bee engine .
Old 04-17-2007 | 08:00 PM
anyone[&o]
Old 04-17-2007 | 09:19 PM
You may get better help on the engine forum or control line forum. I think Cox engines like high nitro high castor fuel - like 25% nitro and 25% castor oil. They may not run well on other fuel. Also, my Cox engines were always fussy - I had to play with the needle a lot to get a good run.
Where is your tank? The picture does not appear to have a tank.
Old 04-17-2007 | 10:37 PM
WSL
Try your questions on the 1/2A forum. The folks over there were a great help to me and my questions on the little engines. Good luck with it.
