what will burn more fuel?
My Feedback: (18)
RE: what will burn more fuel?
Lean you will burn a lot less fuel because after a few flights you will burn up your engine and it wont run any more.
Rich puts more fuel into the mixture so it will use more. Thats why when the engine is really rich its spitting out lots of fuel.
I wouldnt lean out an engine to save fuel.
G'day Mate,
Not only does the oil lubricate the engine, but it takes away most of the heat generated by said engine, so if run too lean, it will get hotter, & not have the oil content to remove the heat.
My Feedback: (18)
ORIGINAL: Sport_Pilot
It takes away heat, but far from most of it.
