Float mounting
Old 07-13-2007 | 10:07 AM
Default Float mounting
Hello all,
I have a 1/4 scale Decathalon from the late eighties. I am wanting to put floats on it and need help. I have never put floats on anything.
Any tips or websites would be greatly appreciated.
Thanks in advance,
Aaron Casebeer
Alaska
[email protected]
Old 07-13-2007 | 03:01 PM
Default RE: Float mounting
Try the Seaplane forum here at RC Universe.
KW_Counter
Old 07-13-2007 | 10:58 PM
My Feedback: (17)
They need to be 80 % the length of the fuse , backplate to rudder tip. float step is mounted 1/2 inch behind aircraft CG. Top of floats to top of wing need to be about 2-3 degrees negative so you get more lift from the wing. Height of it all needs to put the prop 1-2 inches above the float tops.
Email me if you have any specific questions not covered. Floats are a blast!!
Ken
Old 07-14-2007 | 10:50 AM
Maybe these pictures of my 1/4 Citabria will be of help. I'm also attaching copies of the diagrams from the Chuck Cunningham paper on setting up floats.
ID:	722626   Click image for larger version
ID:	722627   Click image for larger version
ID:	722628   Click image for larger version
ID:	722629   Click image for larger version
ID:	722630   Click image for larger version
ID:	722631   Click image for larger version
ID:	722632   Click image for larger version
Old 07-16-2007 | 02:30 PM
Also, this plane is built, covered and set up for wheels. Which means that I will have to somehow reinforce the fuse.
Aaron
Old 07-17-2007 | 08:41 AM
Since the fuse is already strong enough for the main gear, all that's needed is to strengthen the area where the second float attachment will be. It's easy to put in some lite ply with epoxy and a couple of pieces of triangle stock.
