 Which ENGINE??? >
Which ENGINE???
Which ENGINE???
Old 07-18-2007 | 11:58 PM
Default Which ENGINE???
Hey There,
I just bought a P-51 Mustang...and I want to put a 4-Stroke .91 Engine in it. Towerhobbies has an O.S. FS-91 II Surpass and a Magnum XL-91RFS...The only difference I find is the $80....Is there any other major Difference...or does it really cost $80 to have the name OS put on it.
Old 07-19-2007 | 12:07 AM
A6Ordie's Avatar
Default RE: Which ENGINE???
http://www.chiefaircraft.com/rcmsec/...gnum.html#xl91
149.99 and Magnum makes good engines. If a few bucks doesn't concern you then get a Saito instead of the O.S. or grab the 1.20 Mag
A warbird isn't a 3D'r so a little difference in power isn't going to make as much difference. The Mag might have a touch less power than the OS.
Good Luck,
