Receiver compatibility
I have a plane with Hitec gear installed (RCD3800. which is a 7 channel FM, shift select, 72Mhz receiver).
As long as it's on the same channel as my brother's Futaba 7 channel FM transmitter (72Mhz) he should be able to fly the plane with his Futaba??
