 Monokote question >
Monokote question
Monokote question
Old 12-10-2007 | 10:16 PM
Default Monokote question
Any suggestions on how to get the Monokote to lay flat? It is so hard to work with when it keeps trying to roll back up. No matter how long I keep it held down flat it always wants to curl back up.
Old 12-11-2007 | 12:52 AM
ChuckW's Avatar
Default RE: Monokote question
It normally lays flatter once you remove the backing. If you're trying to hold it flat before you remove the backing, try some weights. You may also get it to lay flat on a smooth surface like glass using windex.
Old 12-11-2007 | 03:13 AM
once you remove the backing rub the backing across the monocote to discharge the static electricity..this will help it lay flat
