GMS Engine
NS, CANADA
Hi all does ant one have the GMS 76 Engine I am trying to get the piston sleeve out and having a problem it will only come up about 1/16 of an inch got any ideas . I have already tried to cool it down bye putting it in the freezer for a few hours but no luck . I dont want to damage it bye forcing it . any help would be awesome thanks.
hyflyer9 [8D]
hyflyer9 [8D]
My Feedback: (9)
I use a piece of 1/8" brass tubing that I flatter about a 1/4" on one end & bend 90 degrees . Put the crank back in with a prop on it . Hook the tubing hook part in one of the ports inside the sleeve , heat the engine with a heat gun or propane torch & turn the prop backward & that should lift the sleeve out. Use a heavy glove & don't burn yourself. Works for me ! Give it a try. MAX H.
NB, CANADA
Clarence Lee recommends a copper glow plug washer be placed in the exhaust port to help jack the liner out.
Personally, I use a zip tie head in the exhaust port. Nylon is softer than copper.
Never had much trouble jacking one out....
J
J
I think I would choke up the $99 for a new one and save the hassle
http://www3.towerhobbies.com/cgi-bin...&I=LXDXL7&P=SM
-Johnny-
-Johnny-
