optic 6
Old 11-03-2008 | 06:17 PM
Default optic 6
I want ailerons and split flaps. I don't want flaperons or crow.
How and what do I do?[:@]
Old 11-04-2008 | 09:49 AM
Default RE: optic 6
Come on you Hitec reps! Give me some answers or I'll stick it in the 5 and 1 slot.[:@]
Old 11-04-2008 | 09:56 AM
Default RE: optic 6
Try posting this in the Hitec forum, you will probably get answers there.
KW_Counter
Old 11-04-2008 | 10:29 AM
carrellh's Avatar
Default RE: optic 6
I think your expectations for a reply from a Hitec rep are too high. If the RCU time stamps are correct:
Question posted Monday afternoon at 5:17
Follow-up posted Tuesday morning at 8:49
If any of the Hitec reps do read the "Questions & Answers" forum, they probably do it during regular business hours.
If you just want flaps and ailerons, plug flaps into 6 and ailerons into 1.
If you're trying to have the flaps and ailerons coupled for 'full span' ailerons, plus separate flaps, I think you need at least 7 channels and multiple mixes.
2 aileron
2 flap
1 elevator
1 rudder
1 throttle
Old 11-05-2008 | 09:49 AM
Default RE: optic 6
thank you for your advice.
I won't be changing radios.
The 5 slot will give me on or off. I don't have retracts so this slot is open.
I have a "y" on aileron servos plugged into slot 1.
Is this all I can do with the Optic 6?
Robert[&o]
Old 11-06-2008 | 01:22 AM
buz2au's Avatar
Default RE: optic 6
have a look at this tutorial it may have an answer for you http://www.hitecrcd.com/product_file...icTutorial.pdf
