 Bob Dively Liquid Mask >
Old 03-24-2009 | 01:13 PM
Default Bob Dively Liquid Mask
Has anyone used BD to "mask" off dubro hinges while painting. Will it wash off or peel off? I'm using KlassKoat and don't want to use masking tape. Khelsea
Old 03-24-2009 | 06:02 PM
FILE IFR 's Avatar
Default RE: Bob Dively Liquid Mask
I use the liquid masking sometimes, but not for hinges.
For hinges, I neatly coat the knuckles of the hinge with Vaseline or white lithium grease then wipe off when the paint is cured.
In the past I've done the same technique for CAing the hinges in balsa... Keeps the CA out of the knuckles.
Old 03-24-2009 | 07:22 PM
MX240's Avatar
I only use vaseline to keep the epoxy off installing the hinge. I have painted a lot of hinges with all kinds of paint. Never had a problem with the hinge not working free. I would be afraid of getting greese on the parts you want to paint and screwing that area up.
