4 Stroke engine vs. 2 Stroke
ORIGINAL: Avaiojet
Should I stop living in the past with my older but not used engines?
Should I just consider new engines which are made better, lighter, and are more reliable. Or are they?
Charles
Charles
If it weighs 20 pounds when you're done then you will need those 1.20 engines.
I only have one Enya 120R. the other Enya is a 120.
I would have to look for and purchase another Enya 120R. Mine is NIB.
I guess the Moki 1.8 is a bit large for the job, especially for a 80" twin?
Charles
Charles
Shoot man, I'd use the Webra 1.20 engines then. You got 2 already. They are lighter than the Moki 1.80 engines. Everybody else seams to think the Enyas or Webras will turn the 14" props. I know Master Airscrew makes a 14-7 prop in 3-blade configuration. Probably work just fine.
RC Pilot,
One of my Webra 1.2 is a rear exhaust engine. I forgot about that. The other is a ringless Speed 120. I would have to look for another 120 Speed without the ring.
Charles
Charles
#31
The most important thing is the project your trying to develop. the sound produced by a 2 stroke is more appropriate for a warbird type plane while the 4 stroke fits wwI or slower civilian type planes. I love the sound of 4 strokes but not on a quickie or formula 1 style of plane. the next thing to consider is that 4 strokes run better standing up while two strokes can be on their side or up-side-down. whatever you decide good luck.
