 Locktite CA Question >
Old 04-07-2010 | 08:45 PM
Default Locktite CA Question
Has anyone used Locktite brand CA for balsa construction or repair? I'm thinking of their 'liquid' CA. Is this stuff thin enough to wick into balsa? I've got some moving damaged planes to fix and the last thin CA I bought at the LHS (20 miles away) has plasticized too much to be of any use [:'(]. Home Depot carries the Locktite line of adhesives and it's LOTS closer.
John C
Old 04-07-2010 | 09:53 PM
Steve Percifield's Avatar
My Feedback: (14)
Default RE: Locktite CA Question
I have built entire airplanes with it and like it a lot. Gorilla glue also has a ca type glue that I have used . I like both but I especially like Locktite.
steve
Old 04-07-2010 | 10:42 PM
Thanks Steve. By the way, I've moved from SC to CO so didn't get to see you at a Dawn Patrol fly in in IN. Good times back in Newbern and at CERALand.
John C
Old 04-08-2010 | 05:21 AM
My Feedback: (14)
Damn, John C.
I didn't make the connection! Wow, good to hear from you, apparently all is well. I was talking about you the other day, I had a guy ask about an RC Nobler. Remember the day your battery came out in the loop???
Glad to see you are still modeling. Stay well
steve p
www.hoosierdawnpatrol.com
Old 04-08-2010 | 05:23 AM
My Feedback: (14)
The locktite seems to be somewhere between the thin and thick we get from the hobby shop. I built a 1/3 N-17 with it. Good stuff!
steve p
Old 04-08-2010 | 06:54 AM
Snuck up on you, didn't I . Yep, I remember the RC Nobler. It wasn't the greatest flier, but with present day equipment at least there would be some room in the fuselage for the gear. I had forgotten about the battery falling out .
Sounds like the Locktite CA won't work for what I need though as I'm trying to fix broken balsa under Monokote by wicking in CA to fix the broken bits.
Regards,
John C
