Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC 1/8th Scale Buggies
 Starter box, what am i doing wrong? >
RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Old 04-25-2011 | 05:17 AM
My Feedback: (83)
Default Starter box, what am i doing wrong?
I bought an ofna starter box and i can't figure out if i'm doing it right or not.. i push down on the car and it seems to take some of the rubber wheel of like i get the rubber wheel dust? what am i doing wrong? Terry
Old 04-25-2011 | 05:30 AM
1320Fastback's Avatar
Default RE: Starter box, what am i doing wrong?
Sounds like the rubber wheel is not lining up with the cars flywheel, or the opening in the frame for the flywheel is not long enough.
On one of my XTM's I had to open up the width of the opening in the frame so the starter wheel could
go up high enough to touch the flywheel without hitting the frame.
Old 04-25-2011 | 05:41 AM
tommygun32's Avatar
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
What car and motor are you trying to start up.
Off the bat, loosen the 4 holding screws that keep the four rubber tabs in place. Move these tabs to their furthest outward positions.
Now put the car on the starter and make sure the starter wheel lines up perfectly with your flywheel. Now push the four rubber tabs back into place against the frame of your car, making sure the car doesn't move anywhere. Now tighten the screws back up. This will ensure you car lines up perfectly every time and doesn't move around.
Let us know how it goes and good luck.
Old 04-25-2011 | 06:38 AM
My Feedback: (83)
thanks everyone for the replys will go home and try these methods out and see what happens....Terry
Old 04-25-2011 | 09:17 AM
K_B's Avatar
K_B
It's much easier to line up the wheel with the the chassis opening if you take the engine out of the car.
Old 04-25-2011 | 01:03 PM
My Feedback: (83)
all three of the ofna 9.5 violater are running two .26 engines and one .28 engine if that helps any...thanks Terry
Old 04-25-2011 | 11:09 PM
tommygun32's Avatar
What battery (ies) are you running in the starter box and are they (it) fully charged?
Old 04-27-2011 | 10:59 AM
Have the pull or roto starts been removed from the motors?
