MBX5R Help...
MBX5R Help...
This may seem like a dumb question or you may think I'm dumb for not knowing and maybe so, but I could use a little help. A few years ago I built a Mugen MBX5R buggy with an OS V-Spec .21 engine. Recently it developed some problems so I took it apart. It was quite worn. I decided rather than rebuild it, due to the extensive useage it had, that I'd just replace it with the same exact engine. I commenced to put in the new engine. I had a complete flywheel assembly that I had purchased some time ago and never used so I started to put that on the new engine. In the kit is a tapered cone part # C0702B. I didn't see that on the old engine, but second guessing myself I wondered if I put it together wrong in the first place so I went to the instructions which are quite vague. It only says: "Use C0702B when not attaching to the engine". Hmmm, what the heck does that mean? Does anyone have a clue on whether I should use this part or not?
http://imageshack.us/photo/my-images...talationi.jpg/
RE: MBX5R Help...
Gotta lvoe mugen instructions. Matched only by the epic fails going on in their body design department.
Yeh, that's your flywheel collet, use it as shown in the pic. GL!
RE: MBX5R Help...
Well I'm really guessing at this point. As you can see the instructions are somewhat vague and since I built it about 4 years ago, I don't remember either way as to whether I put it in or not. I know when I took it apart there was just a faint remnant of something there that just crumbled in my fingers almost like build up of dirt or something. Certainly nothing as large or hard as the collet so if it was in, it disintegrated.
