tires and wheels
Easiest way...
Preheat oven to 350 degrees. Place tires on a foil covered cookie sheet. TURN OVEN OFF. Immediately place cookie sheet on middle rack in oven. Let them stay in oven for about 45 minutes. Remove. Let cool to room temp, otherwise you can stretch tires. The glue should be crystalized and you shoul dbe able to pop tires off.
it is called acetone, or nail polish remover...but plain acetone is cheaper, it is the active ingredient in nail polish remover. put enough in an airtight box to immerse the tire and leave em overnight, in the morning, the tires will come off.
So wear a rubber LOL
Seriously, make sure you follow the safety precautions on this stuff.
P.S. Tower has debonder for sale, sorry guys looks like somebody else is making it already.
