RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
os v-spec
Old 08-07-2004 | 07:13 PM
Default os v-spec
Will the v-spec last as long as an rb? Wondering because I want to make sure before I get it.
Old 08-07-2004 | 09:58 PM
Default RE: os v-spec
No one can give you a straight answer on that because the V-Spec is too new. However, One of the OS drivers has recently just retired his V-Spec after 7.5 gallons. Thats damn good for being a race tuned motor.
Old 08-07-2004 | 10:01 PM
That sounds really good because they get the most performance possible at the expence of a shorter life.
Old 08-07-2004 | 10:49 PM
I'm looking at an add for it right now in Radio Control Car Action magazine. If the specs in the ad aren't an exageration and a race tuned engine will survive 7.5 gals then it sounds like an engine worth looking in to. These are the specs from the ad:
O.S. .21 VZ-B V-Spec-T (P)
Displacement: .21 cu in (3.5cc)
Bore: 0.653 in
Stroke: 0.630 in
Practical RPM: 3000-40,000
Output: 2.5 bhp @ 33,000 rpm
Weight (W/O muffler): 12.7 oz (360g)
Old 08-07-2004 | 11:53 PM
so will it or wont it cause iam thinkin of gettin on or an rb
Old 08-08-2004 | 01:36 AM
in the next issue of RC nitro..they dyno the Vspec..so far my vspec is running great..and wouldnt get anything else
Old 08-08-2004 | 02:06 AM
q8's Avatar
q8
if you want a great engine why dont you go for the novarossi 421
Old 08-08-2004 | 03:04 AM
i think with the 421b it is touch and go some people have bad luck with them and some people don't i don't think it is worth the risk. but some people might think other whys. the v-spec looks like a very good motor i would wiat untill after the worlds and find out who was running the v-spec and see what they said about it and if it is still running.
Old 08-08-2004 | 05:25 AM
The Worlds are almost over. The V-SPec did Great. and So did the 421B.
Between those two motors I would go for the Top 421B. Anything in this hobby is touch and go. One moron gets something, doesnt treat it right- breaks it in some cold method, shoots a rod through the side of the case- leaves a bad taste in everyone elses mouth. (LoL- J/K Grahama)
Old 08-08-2004 | 11:09 AM
What fuel would you recomend blue thunder 20% race blend and odonell 20% race, witch one has a higher % of oil. They are both $20.00 at my hobby store
Old 08-08-2004 | 11:47 AM
OS on fourth in the Worlds, not bad for this new engine. RB on first. Nice...
Old 08-08-2004 | 02:04 PM
I'm running the V-spec as well. On it's 4th gallon now and compression still good.
The 421B is also a good choice, but we've had 3 instances of the cooling head breaking the top fin completely.
RB of course would be a great engine, having just won the championship.
I'd hold out on Sirio as there is a newer version coming out.
The thing I like with the OS is parts are WAY cheaper than italian engines where I live.
Old 08-08-2004 | 02:44 PM
mk999's Avatar
I could have told you before the worlds an RB would have won 3/4 of the field run them!!! Although I would have said Kyosho as well but a mugen won it
Old 08-08-2004 | 03:14 PM
shooky's Avatar
Get the one that is cheeper OS V-spec or the RB WS7II either motor is great and I think that if you look around you can get RB parts just a quick and as cheep....Piston Sleeve and rod for either is $160.00 so the choice is literaly 50/50 I use a RB and have nothing to say but praises all around..RB makes a great motor..the V-spec I am still waiting for more data, from people were I live. That way I can make a good comparison. My friend has an OS and I have a RB we both do well neither is any greater but I do notice that the OS can pull away from me adn my RB takes the corners and the start almost every time...Hope all this helps...
Old 08-08-2004 | 03:35 PM
mk999's Avatar
RB has top end OS crazy insane amounts of bottom end, do you run open or texhnical, high or low grip? if it's low grip go RB unless it's really really technical if it's high grip and technical go OS if it's high grip and open go RB. but it's not that important so if there is a big pricae difference go for cheapest
Old 08-08-2004 | 09:03 PM
What fuel would you recomend blue thunder 20% race blend and odonell 20% race, witch one has a higher % of oil. They are both $20.00 at my hobby store.
Old 08-08-2004 | 09:35 PM
just wondering $20 for how much fuel.
Old 08-09-2004 | 09:14 AM
probably a gallon. Thats how much they go for here as well. Go for the O'donnel, I dont like the blue thunder stuff.
As for the V-Spec, its got plenty of top end as well, if not more than the WS7II- the turbo plug helps out in that department.
Old 08-09-2004 | 09:15 AM
yes it is for one gallon[8D]
Old 08-09-2004 | 09:29 AM
shooky's Avatar
I use 30% O'Donnel and it works great....O'Donnell fuel is TOP Notch and you still get great lube even with a higher %'ages....Long Live O'Donnell
Just my two Pennys
Take Care and GOD Bless
Old 08-09-2004 | 12:34 PM
yea..i would only run Odonnel or Trinnity MHP fuel in my engines..personal preference i guess...but i now run Trinnity all the time..it smells better than OD lol
Old 08-09-2004 | 04:38 PM
shooky's Avatar
ORIGINAL: repete
You realy think so I think OD smells much better,
I guess it is all preference..
They both do well where I live so either is good,
Old 08-09-2004 | 05:22 PM
yea...i guess we have diff smell preferences lol
Old 08-09-2004 | 05:48 PM
I wont run O'donnell ever again unless they come up with a new formula, Whatever is in that gunk they sell makes my engines run hot and perform not up to par. I ran back to back test with the same motor, tuned to each fuel with Maxy's 30%, O'donnel 30% and MHP 30%- Maxy's took the cake with performance and temps, MHP wasn far behind with a barely noticeable difference in performance, similar temps, and O'Donnel just ran wayy to hot and performed like a slug compared to the other two. Motor was a JP Modified P5T with RB 9886 Pipe, stock header and Novarossi Turbo #6 Plug on a 90 (roughly) Degree Hot/Humid day here in Florida.
Old 08-09-2004 | 06:19 PM
man skyline how old are you. are you bill gates son or something you must be loaded. you must have tried everything under the sun. get a rody c5 with a fironi turbo clutch and a nova 9853pipe then tell me it has no bottom end.
