RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Problem with jumping
Old 10-11-2004 | 08:20 PM
Default Problem with jumping
When I land from a jump my engine cuts out, it is not from the flywheel hitting the ground I have tested by dropping to car so it bottoms out when it is idling and the engine doesn't cut out. It was happening at the track and now on grass.
Old 10-11-2004 | 08:51 PM
El Pirata's Avatar
Default RE: Problem with jumping
Can you elaborate a little more. Fuel system leak allowing air to come in? Worn out engine? Throttle position on landing? Idle set too low. Incorrect needle settings. Etc....
Old 10-11-2004 | 09:01 PM
do you land perfectly flat. try and land so it is a bit nose high and tell us wht happens then we will be 100% sure if it isn't the flywheel.
it could be that your clutch is not setup right and when you land your wheels for a moment will bind your engine and cause it to stall this would rarly happen and if it did you should have not clutch.
Old 10-11-2004 | 09:06 PM
..check the clearence between ur flywheel..and ur rear break caliper...on my eb4 if i didnt have my engine lined up perfectly..that would happen..the slight flex of landing would kill my engine..
also..sometimes as an engine wears out..the die from the shock of landing
Old 10-12-2004 | 03:07 PM
My rex p5 is perfectly tuned and is 1/2 a gallon old.The clutch was bought new with the engine. It happens when I land at partial throttle, I have never had this problem before and have been to the track many times.
Old 10-12-2004 | 04:29 PM
..try a diff clutch if u have one..that one could be sticking
Old 10-12-2004 | 06:07 PM
I think I have 1/2 way solved the problem I took out the aluminum center diff. mount, this seemed to help a lot.Now I have to work on tuning the engine.
Old 10-12-2004 | 07:15 PM
what buggy is this on
Old 10-12-2004 | 07:23 PM
Gs Storm Pro
