RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Hyper 7 pbs pullstart
Old 11-08-2004 | 01:30 AM
Default Hyper 7 pbs pullstart
I have a hyper 7 pbs which starts off a box you put it on. Is it posable to fit a pull start to the engine?
The places I use my off road buggies makes draging the box along a pain in the rear end.
If so whats parts do I need?
Thanks Lee
Old 11-08-2004 | 10:22 AM
Default RE: Hyper 7 pbs pullstart
Hi Lee,
It should just be a case of getting a pull start unit that replaces the crank case cover on the engine. Unless you also need to get amodified crankshaft,
If starting with the pull start you may need to loosen the glow plug slightly when starting to help you turn the engine over. Also fitting a pull start can add a bit of resistance which will slow the engine down. Not sure if it would be noticable though.
Rich
Old 11-08-2004 | 11:18 AM
zzman's Avatar
lee- you should really think twice about doing that. you will have a lot more probs w/ the pull start and im shure it is a little bit of a hassel to carry the starter box put believe me the pull start sucks and is a pain to start the motor. and you WILL notice a diff w/ the power loss. ive had pull starts and they are a BIG pain in the a@#!
Old 11-08-2004 | 07:06 PM
You can get a pullstart to the hyper at ebay.
http://cgi.****.com/ws/eBayISAPI.dll...tem=5932040046
This is a great dealer in my opinion.
Old 11-08-2004 | 07:38 PM
Banned
You need the pullstart, backplate, hexshaft and turbofan. But if you like I have the lot off a new engine for £25.
Old 11-08-2004 | 07:46 PM
forget all of your ideas pull starters suck ***** i had to re build mine almost evertime i run it so get a roto start you wont be dissapointed!
Old 11-09-2004 | 01:13 PM
I have a roto staer I use on my savage, so what parts would I need to convert to the rotosatrt?
Thanks Lee
Old 11-14-2004 | 06:10 PM
Spoke to the local model shop today and they recon new cam etc needed to convert the engine to pull start and no roto start avalable.
So If I want to go to a pull start, it would be just as easy to bung a new engine in.
Has anyone fited a .26 to a hyper 7?
And if so, which one, Im on a tight git budget.
Old 11-14-2004 | 06:39 PM
A guy at my local track has a .26 in his Hyper Pro.
I think it's a Vertex, which should be rather inexpensive.
