RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
engine settings
Old 12-21-2004 | 09:48 AM
Default engine settings
i was wondering if any one knows the base settings for a prp swift stock engine as i can find them anwhere and they are not incluided in the manual it just says that they are preset
any help with be good thanks
Old 12-21-2004 | 10:51 AM
Default RE: engine settings
Really- there are no base settings on a nitro engines carburetor. Because your geographic location, weather, fuel, plug, pipe all play a role in the carbs tuning. I'd say just richen up all the needles a couple turns and then lean until it starts. Then follow a good break-in method of your choice. I recommend the Bess Method for break-in.
Old 12-21-2004 | 06:24 PM
i believe the mayhems motor is very simular to the 24.7 engines i may be wrong but check that out it may help you.
Old 12-21-2004 | 07:50 PM
Banned
most engines nowadays are around these settings.
1 mm throat gap , LSN 3 - 4 turns out from closed and the HSN 3 turns out. Not the garunteed figures for you but they should get her going.
