RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Lightning 2 Cutting out
Old 01-07-2005 | 05:55 PM
Default Lightning 2 Cutting out
Hi all,
Back in September I bought a Hot Bodies Lightning 2 RR and love it so much I am entering next years nationals, but I have run into a problem. A month or so ago, I was running around my track and it was performing great. I refilled it for the 3rd run in a row and blipped the throttle just to make sure the engine would still be kept alive. As I accelerated away, it cut out. I was confused to say the least. I restarted it and ran it around slowly and it seemed fine. Built up the speed and as I got to half throttle it cut out again. I restarted it and slowly accelerated away again. Got to half throttle and it cut out. I reckon it's had 30 + runs, so the engine is broken in. I used O'Donnell 25% fuel. Is anyone able to shed light on my predicament?
Regards
Paul
Old 01-08-2005 | 01:22 PM
lightningtwo's Avatar
Default RE: Lightning 2 Cutting out
Adjust the midrange and high-speed needle. The lightning should use 20% fuel but I'm using 25% too.
Also how did u run it in? You should keep out of high rpm. When breaking in did u raise the car and let the wheels move slowly for 5 tanks? A lot of the time it's when you are breaking the car in that causes this.
Old 01-08-2005 | 02:37 PM
GeForce's Avatar
Do you have a fuel filter? If so, check it. If there's muck and stuff in it it'll restrict higher levels of fuel flow.
