help with 9.5 wheel nuts
PA
i have a problem were my wheel nuts fall off after goin awhile. is there a way to fix it. im about to just put some blue locktite.
RE: help with 9.5 wheel nuts
NO
NO NO NO
Do not use locktight. Simple solution
retighten them after everyrace.
If you want try a little anti seeze just to provent them from slipping off but recheck every race.
i havea 9.5 myself and i just check mine all the time. GEt the wrench from ofna that is for the lugs it makes it alot easier.
NO NO NO
IL
and if they are just wore out ebay has them getto cheap! and check the wheels sometimes they strip out where the hub goes and they will spin and the nut tends to work its way off.
