RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Problems with pipe
Old 02-08-2005 | 02:16 PM
gfkostas's Avatar
Default Problems with pipe
I have a hyper 7pcr and even though I have put zip ties on the pipe it still keeps fall off.What can I do about it?
Also is 230c appropriate temperature?
Old 02-08-2005 | 02:29 PM
zzman's Avatar
Default RE: Problems with pipe
i had the same prob. i used a small propane torch and heated up the end of the pipe(not header) and used some small channel locks and made a flange on the end so it wont slip off. just be careful not to do it all at once and rip it. just take your time and keep working it little by little and curve up the end. the end may be a bit sharp and may cut into the rubber connector. so i used my dremmel and rounded it and smoothed the edge. its a for sure fix. then use 2 zip ties on each side. just keep it HOT and work it slow.
joes75's Avatar
The coupler is slipping off the exhaust because the raw fuel is getting in there and making it slide off. Not much you can do, maybe pick yourself up a 1 piece tuned pipe that way you wont need the rubber coupler. 230 Celcius? Isnt that like over 400 F, do you want to cook your engine or something? Richen it up or that engine is toast.
Old 02-08-2005 | 02:43 PM
gfkostas's Avatar
Sorry I meant 230F. What do you think about the RB 2020P joes75? is the new one from RB and it has 3 chambers instead of the 2 9886 has.
http://www.rbproducts.com/mainEn.php...oudes_inline21
Old 02-08-2005 | 02:54 PM
monte100's Avatar
here some good info "how to bullet-proof a tuned pipe"
http://www.rcnitro.com/rn/articles/bulletproof_1.asp
