Quick question about pipe
This is the OFNA 086 pipe right? http://rc-mushroom.com/product_info.php?products_id=767 whats the 'hong nor' means?
My Feedback: (158)
ORIGINAL: spokman
The header isn't welded correctly. Build defect. I had thought it was a flashing issue that was easily fixed. Returning mine and getting a JP-2.
before picture
Had enough- I heard of alot of people saying that there ofna headers looked like that. SO a while back I took a nova header and an ofna header- results- they were pretty much the same. Both had the little flange there.
WA
What kinda chaps me is that Ofna keeps making them. They just didn't make one bad batch. The just freaking keep pumping them out. How hard is it for that Chinese guy to re-align his weld jig..
i've checked all my RB/Novarossi headers & they're all perfect
even my Picco 069 header was spot on
that step is definitely not a good thing, if you have a step dremel it away for sure
WA
I just got in a JP-2 pipe that I had thought would have a good header on it. It's not centered quite right either. It's much better than the 086 pipe but still not spot on like it should be, still needs dremmeling. My OFNA starter box needed some new connectors for the wires and the bannana plugs didn't have the right size plastic backing pieces. The OFNA plug wrench I got doesn't have a spring for holding the plug in it. I'm kinda thinking of not buying anymore OFNA products.
