fuel filter direction question
i got a dynamite big daddy fuel filter. but it doesn't say which is the inlet and outlet. any help would be apreciated. thank you.
If you bought it brand new and fully packaged and the instruction or box dont say, then its probebly a 2 way filter (either way) if not then you can either wait for someone on the forum who has one to get back to you or you can try it one way and see if the car still works!! thats what i would do.
Adam Forrester
Adam Forrester
AL
The end with the screen (or the filtering device) should be closest to the carb. It should be the side with the rubber o-ring, thats the end you want going to the carb. That way there is a bigger area for all the filtered contaminants to remain.
