THE P5 THREAD
IL
i found this to check your head clearance if the first link doesnt work try the second and its the first vid. "Ultimate Nitro Engine Tuning DVD Sample " nitro_tuning_sample1[1]
http://www.radiocontrolzone.com/cars/video.asp
If I were you I wouldn't take out a shim using 30%, but i might do it using 20%. The engine is designed for 25%, you would probably get a lot of detonation if you took out a shim and ran 30%.
ORIGINAL: jwren00
