Changing Diff Oil
Just a quick question
When putting new diff oil in the differentials, how full of oil do they have to be? A guy at my track was saying something like: Front diff 70% full, mid diff 80% and rear 90%.
Is he on the right track or do you guys just fill'em right up?
Thanx
Thanx
you will get a slightly different effect depending on how much you fill.. the silicone does get fluffed up a little .. more just means tighter.. less just means loser..
NC
I don't guess you have to, but no more work than it is it wouldn't hurt to pull the cross shafts out and spray everything down with a good cleaner! Besides, eventually little metal shavings are going to get in there and eat up your gears if you don't clean them everynow and then! Just my .02
DONT fill them to the top, it will basicly lock your diff and you will lose the point of having a lighter/heavier oil. Fill them up to just above the cross pins (just over 2 thirds) and then drop a little oil down the slots for the crosspins. There should be no difference in the amount of oil in the diffs, all the same. If you have been filling em 100% STOP NOW because it may really mess with your setup.
ORIGINAL: Alden
IL
guys get "leaky diffs" if they fill them up to far.i fill mine just over the cross pins and put my thumb over the pins to hold them down and turn the diff gears to work some of it down or if you have time let it set for a bit. then get it just over the pins.
