Tire removal help?
Bake em.
Turn you oven on to 450 degrees. Place your tires on a cookie sheet, when oven gets to temp. Shut oven off and place tires in oven. Let them stay in there for 45 minutes or so. After this time the CA should be crystakized and you can pop the tires right off.
Depending how well they are glued, you might have to do this twice, but rarely this happens
FL
i have found that baking them workes the best and fastest. i put the oven to 350, and then put the tires on tin foil on a cookie sheet. I leave them in there for around ten minutes or until it is easy to take them off the rim. it should just peel off.
i like to bake mine with olive oil for about ten minutes at around 330 f , then lighly sprinkle some cummin and basil. You can even add tomatoes for that italian feel..
Banned
ORIGINAL: MassiveMods
I'd go with just boiling the tyres, I do and it does just take 20 mins tops and you dont get that molten rubber smell throughout the house/street.
FL
Thanks all, I am really concerned about the smell of rubber in my house. My wife will kill me... If boiling does the trick without the odor then that’s the route I will take. If baking them works but, with odor I can’t afford the wife coming home and saying you destroyed the oven with that burnt rubber smell.
ORIGINAL: had enough
A gallon of Acetone--$8
A 2 gallon bucket w/tight fitting lid--$2
Letting the wheels soak overnight and the tires fall right off the next day while keeping my RC stuff all out of the house so the wife can't complain--Priceless
what does the acetone do to the integrity of the rubber? anything? I just mounted up some brand new crime fighters but screwed one of them up, so i want to remove the tire and re-mount it, and i certainly do not want to compromise the quality of the rubber .
ORIGINAL: atomicjtr
lol
Acetine will really hurt the rubber if you keave it over night..
FL
baking hasn't done anything to my rims and i have reused four or five sets , and baked each several times. Man you guys need to get your pants back from your wifes.
Check this out, I just bolied some pre-mounted Medials. Came with the bright yellow rims, and I dyed them black. Turned the stove up to 6 and let them simmer for 20 minutes. Glue is still totally in tact and strong as it was before. only problem was that the dye wouldn't soak in wherever there was tire glue close to the bead, so I had to do some very minor touching up with a sharpie.
Here's some pics of the results...
My Feedback: (158)
The acetone swells up the rubber, but after the rubber out-gasses the acetone, it seams to return to its normal shape and textute. I've never tried to reuse tires after so I can't say for sure. I usually cut most of the tire off the rim before I soak them. Either way the foams will get wasted.
Banned
ORIGINAL: thebuggyman
ORIGINAL: Uberchav Alex
I get my pants back everytime SHE does the laundry. But I still ain't brave enough to smoke the house out.
he's whipped... mine isnt bravery I just hate burning rubber...
