Engine and Pipe Decision.
VA
The RG is $110 from Tower. Look out for the 10% off code on the main page, that brings it down to $99. It comes with filter assembly and two foam filters.
CMDRacing.com has a special on the MAC .21 for $159 including a spare crankshaft. Full price is $339.
[quote]ORIGINAL: SManMTB
WOW if forgot about tower...thats a good deal
Hmm...Ok well the RG seems the go I think, if im after low end power what would I be better going with, JP-1 or JP-2?
yes,
jp-1 for low/med torque and jp-2 for med/hi torque
btw, does anyone knows, where can I find a jammin pipe somewhere in Europe...
would like to try a jp-2 on my P5[>:] no luck so far...
cheers
cheers
#32
Thing is though, you're putting a low end pipe on an engine with low end power... This will give you crazy torque, but to get speed, you'll need to use a larger clutch bell. What would be better, is to use the JP2 pipe for top end, thereby balancing the performance a little, since the RG lacks a little in top end anyway...just my 2 cents...
#33
Yes, but that it what i am after crazy torque....I only really bash around the backyard and I do race occasionally and the track I race at is like real small...and when I say small I mean real small, the straight is about 10 metres MAX, therefore I am after quite a bit of bottom end..
#35
WI
ORIGINAL: foxy42
#36
VA
Yes that is usually the case. The exhaust design (shape and length of the divergent and convergent cones is the pipe) is dependent on the engine timings. A engine with strong low end has usually lower exhaust timings which matches well with a longer pipe.
#38
Yeah, PRP Swift, So if I was after quite a bit of low end I would be better matching a low end engine with a longer pipe or a low end engine with a shorter pipe?
#39
VA
Low end engine with a long pipe to get the timing right to get the power out of the motor. Then you can gear up a little to get the top end.
#45
hey hereticozzie how does your swift handle? my diff. gears wore out so fast[:@]....has that ever happened to you? for me its mostly in the rear diff.
#47
Ok, how does this sound...O.S RG, Jammin JP-2 pipe and a 13 t clutch bell?
Have a look: [link=http://p202.ezboard.com/fofnaracingnitrotalkbackfrm36.showMessage?topicID= 23.topic]Tuned Pipes Explained[/link]
#48
ORIGINAL: puffer
I disagree. I still think you should go with the JP-1. As most people have commented, the idea is to match your pipe to your engine's strength. Trying to get more top-end out of an O.S. RG through changing the pipe won't give great results for your bottom or top end. If you want top end, then buy a top end motor. If you want bottom end, then buy a bottom end motor. Simple concept. Yes of course, everybody wants it all and I suppose this is one way to try and do it. However, letting the motor perform at its peak and changing your clutching I think is a better way to accomplish this. I don't claim to be an expert.
The pipe for the OS RG and V-Spec is the OS T2050 Pipe.
#49
ORIGINAL: hereticozzie
Cool, OS RG 21 with a JP-1 pipe, cool thanx guys for ur help!!
