How to get the flywheel off?
I have an old Torq engine, I have never taken the flywheel off. According to the manual, after the nut is taken off it should just slide out. But, I could be wrong, it might be screwed onto the crankshaft. All attempts at sliding it off have failed, so I'm assuming its screwed on. But, thats the problem, I am without a crankshaft locking tool. So, withtout one, is there any possibility of removing the old flywheel? [:@]
I'd leave it on, but the current one is larger than the flywheel the MP777 kit came with, and is uncomfortably close to the brake and brakepads.
Any idea's?
Any idea's?
Matt --- I don't think that it is screwed on -- it is just on the brass collett very tight. Do you have a dead blow hammer or a rubber mallett? You may need to knock that bad boy off. A few quick hits to the back of the wheel should do it --- but not too hard - you don't want to damage/bend the shaft.
If you have any more problems - call me at home tonight.
I would heat the flywheel and they carefully (Don't Burn Yourself) try to lightly hammer it off. If not, try some liquid wrench, but try not to get any on the bearing, it will displace the bearings oil
ORIGINAL: slicks
VA
I've got a bearing puller I use for that. I can bring it this weekend if you like.
It's a craftsman, $30 at SEARS. Well worth the money.
OH - Man---- everytime I go to AutoZone I forget to get a bearing puller[:@] You are correct Christian that is probably the best way to get that flywheel off.
I never thought of heating it first before the hammer routine -- that is a good idea too! But I would shy away from using the liquid wrench -knowing me I would get it in the shaft bearing!
ORIGINAL: SManMTB
It just pops right off with that tool.
Nope, it wouldn't budge, I guess I'll be installing the engine at the track next weekend.
Christian, about what time will you be arriving at the track next weekend?
ORIGINAL: SManMTB
I guess 12 on Sunday, maybe earlier. I might be there on Sat too.
Cya all there [8D]
NC
Put a short 3mm bolt in the end of the crankshaft, and thread it all the way in. This way you don't ruin the tip of your crank. Then use the puller. The screw should just turn right out. You can place a wrench, or some other flat fork behind the flywheel for support, and hammer it loose. But just remember, your crankshaft will be pounding the inside of your backplate. It's a good idea to remove the backplate if you use this method.
Put a bolt in the end of the crankshaft, support the sides of the flywheel in a vice with the engine between the jaws (free to move dont tighten the vice) then gently tap the end of the crankshaft with a mallet...
Should pop right off..
OH
just for future reference, what i use is a screwdriver between the crankcase and the flywheel and gently pry it off working my way around the circumference
my $.02
my $.02
