Picco P7r Question?
MA
Picco P7r Question?
Hey you guy's running this engine what standard Glow plug are you running and with what fuel?
I Have a new Jammin pro with a Jp2 Pipe and I will either be breaking it in and running
O'donnels or Byrons 20% or 30% Depending on what comes in.
If I run the Byron's 25% or 30% do I need a .10/.20 shim
any input is appreciated
RE: Picco P7r Question?
the JP1 would be the best pipe for the P7-R as its a direct copy of the Picco 069 pipe which is the very best pipe for your engine
i just used an RB or Novarossi no6 in my P7-R but apparently the firepower F5 is the better choice (so i was told)
OH
Novarossi #6 30% Odonnell .20 shim...hope you got the EVO with the black case and 1 piece crank...rampaging beast of an engine with a JP1 pipe.
MA
I have a JP-1
Thank you for info I will put that on instead
and I was also thinking of using Byron's 25% for the long run so would I throw on a .10shim
The Novarossi#6 is a med plug right can I use a McCoy#8 until I order the Rossi's?
The byrons I won't be able to get until end of next week and I do not have any shims
I want to break in motor now but all I can get for fuel is Odonnel 20/30% or white lightning
20/30%
I dont know what to do?
20/30%
