plz hlp, engine wont come back down 2 idol
why wont my hyper 8 port engine come back down 2 a idol, when i rev it up and come back down to let it idol it revs 4 a bit then drops down to a normal idol. how do i get it to come back down to a idol straight away with out it running on
Banned
RE: plz hlp, engine wont come back down 2 idol
Nope, richen the HSN a tadge, your leaning out the mill to much and there's not enough fuel to run it at the correct fuel/air mix when it returns to idle, as it sits there it's recovering but revs up till the balance is correct again. You may need to lean the LSN a bit after the HSN is fattened. You'll also notice this symptom is similar to running out of fuel, as in uncontrolable reving up, so there's a clue as to why it's happening.
the hsn is still real rich, iv only just run it in and its blowin heaps of smoke thrugh the whole rev range
ORIGINAL: Uberchav Alex
AZ
Actually if your LSN is adjusted correctly, it will give you a high idle for 6-10 seconds then drop down to the low idle.
If the idle doesn't change while adjusting the Idle screw, it's an Air leak.
Banned
ORIGINAL: J_Bone
