RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Clutch Bell needs replacing...
Old 09-23-2005 | 10:08 PM
Default Clutch Bell needs replacing...
I have an Ofna LX Pro basher and the clutch bell has worn out and no longer connects with the spur gear. Do I only have to replace the clutch bell, or is it a good idea to replace the spur gear at the same time? I saw a titanium(?) clutch bell on Ebay--is it worth the extra $ to get one of these instead of the stock ones, i.e. will it last much longer?
Also the stock clutch bell was 14T, if I replace it with a 13T would I notice much difference in low/top end?
Old 09-23-2005 | 10:26 PM
Default RE: Clutch Bell needs replacing...
ORIGINAL: mattreynol
In reference of the clutch bell, 13T if for more low end and 14 or 15 for top end.
Old 09-23-2005 | 11:55 PM
Banned
14T is the most common bell on the race scene, the Titaniun spur aint worth it and this time set the mesh up correctly.
Old 09-26-2005 | 12:43 PM
What's involved in setting up the mesh correctly? Is it supposed to be a tight fit? There really isn't any room to adjust anything is there?
ORIGINAL: Uberchav Alex
Old 09-26-2005 | 02:33 PM
Ya, setting the clutch bell gear too far away from, or even too tight against--the spur gear will wear it prematurely. I JUST now found this out the hard way. I had mine too far from the spur gear and I now need a new clutch bell too.
I heard they are supposed to be tight (so they dont slip past one another), but have a small amount of play. I used a piece of paper to set mine (wedged a piece of paper between the spur and the clutch bell gear). Apparantly I either moved it before I tightened the motor mounts, or I used a piece of paper that is too thick.
Thats one thing no one ever states--how THICK of a piece of paper should I use??? I cut a slice of a post-it--is that paper too thick stock??
Thanks!
Old 09-26-2005 | 03:19 PM
A normal piece of paper normally does the trick.
But it's a question of getting the feel for the correct mesh. When you set it to tight, you can easily feel the added resistance when you roll the car. Then it's just a question of making a tiny (very tiny) movement of the engine until the resistance isn't that big.
Old 09-26-2005 | 05:18 PM
Like that
Old 09-27-2005 | 08:48 AM
This is all good information to know--thanks! I'm not even sure that I need to replace the clutch bell just yet, as shifting the motor mount a little closer to the spur gear may allow me to get some additional use from my existing clutch bell...afterall they aren't cheap!
Old 09-27-2005 | 08:53 AM
MBX5T Maniac's Avatar
My Feedback: (-1)
if the clutch bell doesn't move freely after doing the trick with one sheet on paper, use two sheets instead of one. it will set the clutch a bit further apart
Old 09-27-2005 | 09:09 AM
Foxy's Avatar
That's top advice there from MM, no sarcasm intended. It's better to fold a sheet of photocopy paper in half (so it's like two sheets) for nitro engines, for electrics, only 1 sheet. To answer dean's post, yes, 1 post-it is too thin!
