Losi 8ight Group... If ya got it lets hear about it!!!
#1730
RE: Losi 8ight Group... If ya got it lets hear about it!!!
hey guys, I have a question, When I rev up my mach427 and let it go back to idle it stays reved up for about 2 seconds then goes back down to idle. Could it be that the low end is too rich? when I do the pinch test it takes the engine about 3-4 seconds to shut down.
#1731
take you carb off a clean it throughly, it could be sticking. Make sure the slide action is nice and smooth. Also make sure that the servo is pulling it nice and straight, in other words the arm is not at a severe angle when pulling it open or closing it.
#1732
MB, CANADA
ORIGINAL: pyromania
a 2 stage idle will be pretty normal for a novice tuner....i would'nt worry about it too much.
#1734
MB, CANADA
ORIGINAL: rc rock
what is i exactly???? i mean what causes it????
idle's a little too high...and possibly a little fatt on the bottom.
or DOUBLE check the linkages.[sm=thumbs_up.gif]
#1736
MB, CANADA
ORIGINAL: pyromania
i'll check the links and tune the low using the pinch test. I doubt it is sticking since its nice and smooth.
carb's dont act funny till there hott....make sure its silky smooth Right after running a couple tanks.
#1737
FL
ORIGINAL: pyromania
#1738
Yeah I have the stock return spring on the carb. I tuned it to the pinch test and it still does it. I'll check the carb once its hot to see if its smooth. If its normal then i'll just leave it like i have it tuned right now.
#1739
NJ
Hello guys, it’s been in the works for some time but it finally happened. I traded a HPI Savage for Losi 8ight buggy. He is not a buggy guy as I had to rebuild it in the spring so we just did the swap last night. As I was looking at it, it needs some work. So I need your help as to what to upgrade. The rear shock tower is bent so that needs to be replaced and I should replace the front also. I know they make after market parts but I have not look yet. I thought I would check with you guys since you will know what works and what does not. The engine is not staying with the buggy it’s going in the savage so anybody know of a good .21 to put in this. I am thinking OS engine. Money is not a problem as I want to rule the track in the spring. I have been using an old Ofna Ultra GT to race so this is a big step up. Thanks for your help.
#1740
MB, CANADA
Pro kit tower's will fix that problem......and looks like you need a rear shock shaft....as for a motor...depends on your budget and how much u really want to spend.
#1741
NJ
ORIGINAL: INTEGRA
Team Losi Shock Tower Rear: 8B
[LOSA1736]
#1742
MB, CANADA
ORIGINAL: rcbeep73
are you talking about this shock tower. I had found this on A Main Hobbies
[LOSA1736]
ORIGINAL: INTEGRA
[LOSA1736]
that would be the one.
#1743
NJ
Thanks, any other mods i should do or think about. I know the servo tray is weak but i have an idea on how to fix that.
#1744
MB, CANADA
ORIGINAL: rcbeep73
#1746
MB, CANADA
RE: When will we see the Losi 8ight???
ORIGINAL: chocolatatious
Where you guys use the heavy duty diff case if you had to
huh ? do we use the HD cups u mean ?
#1747
NJ
ORIGINAL: INTEGRA
fix the 2.0 tray huh or do u mean the 1.0 ? the steering rack plastics and new alum servo saver would also be a wise idea as they have been redesigned as well.
ORIGINAL: rcbeep73
#1748
ok here it goes......
i just did what you are doing not to long ago. i upgraded the shock towers,shock caps, front spindles,chassis braces(front and rear), kings head hingepin brace. and i have not broken one thing yet except my clutch witch i think i now fixed. but unless you have the money just fix whats wrong and replace parts later since u have to get a engine. i will provide links to all this at the bottom. as far as your shock towers. if you replace the rear with the upgraded one you should do the front at the same time. and the engine that i love and that is ran in prob 3/4th of the buggys at my track is the O.s. .21 Vspec.
shock towers
front-http://www.amainhobbies.com/product_info.php/products_id/7698
rear- http://www.amainhobbies.com/product_...oducts_id/7700
shock caps(x2) http://www.amainhobbies.com/product_...oducts_id/7741
spindles http://www.amainhobbies.com/product_...ducts_id/11586
chassis brace
rear- http://www.amainhobbies.com/product_...oducts_id/9774
front - http://www.amainhobbies.com/product_...oducts_id/9773
shock towers
chassis brace
#1749
NJ
ORIGINAL: Losi Racer
shock towers
chassis brace
shock towers
chassis brace
[LOSA4417] It says not for the RTR buggy. I have the RTR buggy why wont it fit? Also is the shocks smaller on the buggy then the truggy.
#1750
MB, CANADA
No difference in the shocks from trug to bug....and imo the alum spindle's and chassy braces are Not needed.
