Hyper 7 .28 engine trouble.
Hi,
I am having some trouble with the hyper 7 .28 mach engine. When the car is stationary the engine can suddenly making a loud prolonged (almost defaning!) noise and start moving forward by itself. Do you know what might be causing this?
its not the fuel tube ur lsn r hsn is to lean i had same problem richen ur fuel mixture only lean to the point car stay stationary with out un helthy whining and stop as perfromence gets less.
I think the HSN may be too lean so ill change that. There is still lots of smoke coming out when accelerating so can i lean the LSN a bit more? I did see air bubbles at times when the car started to scream really loud when stationary so i'll change the tubes just incase
