RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
servo for hyper 7 pbs???
Old 03-18-2007 | 02:07 PM
Townsley's Avatar
Default RE: servo for hyper 7 pbs???
Rs43EVOman , can that plug into the stock reciever box? and use the stock radio? and do you know what battery cell pack i could use with the stock parts on my buggy. thanks
Old 03-18-2007 | 02:50 PM
Foxy's Avatar
Yes, it's a direct fit, it's the one I recommended to you in my previous post. Here's the link again...
http://www2.towerhobbies.com/cgi-bin...?&I=LXTT13&P=7
Old 03-18-2007 | 02:58 PM
Townsley's Avatar
oh yea. thanks =] for all your help. do you know a battery cell i could use for my reciever and servos? thanks
Old 03-18-2007 | 03:03 PM
JamieKerr's Avatar
You need something like this as a example ( http://www.modelsport.co.uk/?CallFun...n&ItemID=24135 this is what i just brought for the time being, the battery pack for servo and reciever, and the charger to fit it
Hope that helps
Old 03-18-2007 | 03:06 PM
Townsley's Avatar
would this work.....http://www2.towerhobbies.com/cgi-bin...?&I=LXNMD6&P=7
Old 03-18-2007 | 03:10 PM
  #31
JamieKerr's Avatar
you really want the triangle version like the link i sent, that flat pack might not fit into the battery hatch the triangle one will def fit, remember you need that type of charger too.
Old 03-18-2007 | 07:27 PM
  #32
ya foxy42 i have seen them on here and listen to them a lot too. you all give great information to everybody
Old 03-19-2007 | 03:34 AM
  #33
Townsley. For the hyper the flat pack you suggest is the best. The hyper has a different receiver/battery box from most buggies and the flat ones are the best fit. You should have 2 battery holders with you buggy. Just choose the flat one.
Old 03-19-2007 | 04:47 AM
  #34
JamieKerr's Avatar
Yea i havent tried the flat pack ones i have only tried the triangle ones they still fit in ??
Old 03-19-2007 | 04:51 AM
  #35
The hyper 7 comes with 2 battery boxes (more like holders really as they're not boxes). One for a flat pack and one for the 4 AA pack that comes with most radio gear. The hump back ones will fit in the box for 4 AA's but its not a great fit, whereas the flat pack ones are. Of course you can use whatever you wish but the flat packs fit better.
Jamie your hyper 8 has a completely different receiver/ battery box and hump packs will be fine for you
Old 03-19-2007 | 04:53 AM
  #36
JamieKerr's Avatar
Arghhh i see im going by that they were similar the the hyper 8 my fault lol!!
Old 03-19-2007 | 04:17 PM
  #37
Townsley's Avatar
just wondering..does any one here have a hyper 7 pbs, and the servo was messed up when they got it? it made me mad cuz it wouldnt even hardly work. wellt hanks for all your help guys. =] appreciated it.
Old 03-19-2007 | 04:21 PM
  #38
JamieKerr's Avatar
I'm afraid not i have a Hyper 8 Pro Kit, with Hi-Tec servos and Go .21 7port engine, hopefully you can get it going again lol!!!
Old 03-19-2007 | 05:20 PM
  #39
Foxy's Avatar
ORIGINAL: Townsley
Hey man, as I mentnioned before...don't go buying expensive servos until you have totally checked the entire front end for steering problems. To answer your questions, yes, my steering assembly was pretty messed up on my RTR PBS, I had to disassemble and reassemble it due to binding problems caused by excessive droop etc... I find it unlikely that your servo works in one direction and not another, unless it has gear problems. You REALLY need to check the car.
Old 03-19-2007 | 05:23 PM
  #40
tgwolfwood1981's Avatar
for steering Hitech HS-645MG ($40), and for throttle/brake Hitech HS-325HB ($12.99)
P.S. budget minded by the way, also that HS-645MG is one hell of a steering servo for the money.
Old 03-19-2007 | 06:05 PM
  #41
JamieKerr's Avatar
You just described my servos lol
Old 03-19-2007 | 07:49 PM
  #42
Townsley's Avatar
it seems to be only stiff when it turns right??? liek its real slow and stiff past a certain point then stops and is hard to turn back. im pretty sure its not in the front end because all the parts seem pretty loose that help it turn.
Old 03-19-2007 | 07:50 PM
  #43
Townsley's Avatar
REQUIRES: Futaba J, Hitec, JR, or Airtronics-Z radio system
this is for the Hitech HS-645MG, so does this mean i cant use it with the stock radio that the buggy came with? lol
Old 03-20-2007 | 03:01 AM
  #44
Foxy's Avatar
It's describing the input on the receiver again (same thing you asked about plugs). My friend, STOP WORRYING!!! It'll go straight in.
Old 03-20-2007 | 07:28 PM
  #45
Townsley's Avatar
ok guys..ig ot it narrowed down. What do you guys htink would be the best servo for the best price for the steering servo on my hyper 7,
http://www2.towerhobbies.com/cgi-bin...?&I=LXUZ80&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXUZ89&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMUS4&P=7
Old 03-20-2007 | 09:32 PM
  #46
rc_dude1's Avatar
the 326 took a dump on me, I run hitec 645mg for steering and 625 for throttle / brake. when you looking for servos dont cheap out, get atleast that or better.
