Diff Oil
NC
I'm putting some new oil in my car for the first time and had some questions:
1. How do you clean them out? With just paper towels or with soap/cleaner?
2. How full do you fill up the differential? do you fill it with the gears inside?
WI
use some denatured alcohol, q-tips, paper towel or old bath towel you dont use. make sure you take the gears out.
fill the diff a little past the cross pins (gears have to be in). fill it about 80% full, which is basically just a little over the cross pins. when you first start to fill it up, put in a little bit, then rotate the gears so that the oil fills in the air pockets. then fill it the rest of the way.
