RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
OCM BUGGY THREAD
Old 01-04-2008 | 08:36 PM
  #101
Default RE: OCM BUGGY THREAD
i was just kiddin.
Old 01-04-2008 | 08:37 PM
  #102
your crazy lol.
Old 01-04-2008 | 08:40 PM
  #103
i knew that! haha!!
Old 01-04-2008 | 09:23 PM
  #104
ORIGINAL: dbuggyracer
no really it just the site were we go and update our info.
Powers is right, the site is not ready for the public yet. Shouldn't be much longer.
Guys....post all your setups and build tips fairly often so people looking for that stuff won't have to look real hard.
Old 01-04-2008 | 09:27 PM
  #105
ORIGINAL: DaRcGuru
sure is, hows everything gong with OCMs in your area?
Buggy and truggy both are doing VERY well over here....Alan has assembled a really good team and it shows.
Old 01-04-2008 | 10:10 PM
  #106
ORIGINAL: skeller
ORIGINAL: DaRcGuru
i am looking for a really good year for OCM this they have a good set of guys and the products just keep getting better.
Old 01-04-2008 | 10:26 PM
  #107
Alrighty great stuff, and no doubt it ll be a great year.
Old 01-07-2008 | 05:43 PM
  #108
lets not let this thread die again!!!
give me a bit, and i will post my setup
Old 01-07-2008 | 05:51 PM
  #109
Nick Sartor's OCM Kaos Setup
Front...
Upper arm insert..... 1* Hole up, 2mm shims under top plate
Lower arm position(anti-dive).....1* Hole down
Front inboard toe-in position.....0*
Steering knuckle position.....lower hole
Anti-roll bar(sway bar).....Stock
Upper arm Spacer.....All shims in front of arms
Camber angle.....-2 deg.
Toe angle.....+2 1/2 deg.
Steering Ackerman Location.....Center Hole
Shock Locations.....Inside hole at Tower and Outside on Arms
Shock Oil.....Trinity 60wt
Shock Pistons.....1.4x4
Springs.....OCM Blue
Diff......5k
Center....5k
Rear.....
Toe Block.....Stock
Toe-in Angle.....1.25 Out
Anti-Squat.....0
Upper Arm Location at Upright.... Center Hole
Upper Arm Location at Tower.....Inside lower hole
Upright Pin Position.....Lower Hole
Wheelbase....All shims behind arms
Camber.....-2 deg.
Shock Locations.....Middle hole at Tower and Inside hole on Arms
Shock Piston.....1.4x4
Diff.....3k
Old 01-07-2008 | 06:43 PM
  #110
your setup is similar to mine except the shock fluid but the diffs i run 5,5,2 that seems to work for me.
Old 01-07-2008 | 07:06 PM
  #111
i really need to go thicker in the center diff. maybe 6k or 7k.
keep in mind, i dont have the EVO shock towers.
Old 01-15-2008 | 09:07 PM
  #112
Originally posted on the S-Grid by Scott Porter....
Update on the CRCRC race! Track is very technical, fast flowing, big
difficult jump, and high traction. Easily the most technical track I
have ever raced on. It is quite cold...Burton fabricated OCM's first
EZ Bake Buggy Oven....We went to Target last night and bought up a
couple Tupperware containers. Cut holes in the tops and mounted
electric heaters to it. Drilled a few holes in the sides and now have
our very own Buggy Oven...Works pretty well. Was able to maintain 90*
in the container...As for breakage, the cold did a number on two lower
arms of mine and a knuckle and steering link of Alan's. Considering
how cold it is and the tumbles I took, the buggy has held up well..Only
have five tanks on it and it keeps getting better. Was amazed at how
much steering it had out of the box...Ohh I did shatter one OFNA Tru
Lite wheel...Mental note, if you're racing in cold climates, don't run
the OFNA wheels. Alot of fast guys up here, Truhe looks like the man
to beat. Burton's ride looks fast..Made a couple changes today in
spring rate..Last couple practices went well as he and Truhe were
running right there together. Should be a fun Amain...Good thing I get
to watch!!!! The OCM Team guys should be coming in tomorrow. We'll
keep you posted...
Old 01-15-2008 | 09:24 PM
  #113
go Alan!!!!
Old 01-15-2008 | 10:07 PM
  #114
i would of like to make the race but i have to work[:'(] but good like guys keep is informed.
Old 01-15-2008 | 10:57 PM
  #115
sweet news skeller. weather isnt looking promising for this weekend for us.
Old 01-15-2008 | 11:06 PM
  #116
will probably race at the Liverpool track next weekend, ready for next months NSW state champs.
wish me luck.
getting a good hold on the OCM in regards to driving it aggressivly which has been the over all method that ive had work well for me.
has anyone used the Falcon 21 off road engines? in the same line as BOSS and Ninja, am thinking of grabing one in a week or so..
Old 01-18-2008 | 08:27 PM
  #117
Guys, I got an update from Alan alittle while ago. After the first round of qualifiers he's sitting in 15th overall out of 186 buggies. I will post more as I get it.
Old 01-19-2008 | 04:44 AM
  #118
mad tight! hehe
Old 01-22-2008 | 02:24 PM
  #119
well guys just a couple of weeks left before the ATL race, looking forward to a good race hopefully, so everone get ready and lets have a fun race.
