RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
receiver battery
Old 11-25-2007 | 10:47 AM
Default receiver battery
Has anyone tried this batt and what rate should I charge a 1100 or 1400 mah receiver battery?
http://www.southeastrc.com/Items/Std...lookup=RED5083
Old 11-25-2007 | 03:39 PM
Default RE: receiver battery
Found this one and thinking that a charge rate of 1 amp is fine?
https://host310.ipowerweb.com/~fastr...17bd11875bfc79
Old 11-26-2007 | 01:22 AM
K_B's Avatar
K_B
1 amp is fine. You can calculate charge rate using the capacity of the battery. Your charger charges in Amps. Batteries are rated in milliAmps, so you gotta do some conversions. 1 milliamp is .001 amp. So you just move the decimal 3 places and that give you your charge amperage.
Example:
1400 = 1.4A
1100 = 1.1A
and so on...
You can charge packs at higher amperage, but the performance boost by doing so isn't necessary for a receiver pack and is also hard on the batteries themselves.
Old 11-26-2007 | 04:16 AM
or you can go to cheapbatterypacks.com and have them build you a custom 2600 mah AA pack for 15 bucks. charge at 1 amp max and will last you all day on a single charge
Old 11-26-2007 | 03:38 PM
Allan Aguilar's Avatar
I charge my 1100mah battery at .75 amps. Above 1200mah you can charge 1 amp, if you are in a hurry, you can charge at 1.2 to 1.5 amps just check the battery if it gets too warm, immediately disconnect the charger.
Old 11-26-2007 | 04:03 PM
how does one recharge this battery? Who makes adaptors to go from the servo connector on the battery pigtail to a tamiya connect so that I can connect it to the charger???
