RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
DIFF OIL KNOWLEDGE
Old 01-14-2008 | 05:16 AM
Default DIFF OIL KNOWLEDGE
I was just wondering whether someone could help me, I need to know how much to fill my diff with oil ? will it seal ok basically some general articles on diff oils and how to do it? also is shock oil and diff oil the same thing can it be applied in both cases
Old 01-14-2008 | 07:01 AM
GRANT ED's Avatar
Default RE: DIFF OIL KNOWLEDGE
Do a search for diff oils and you'll find loads of info. Basically fill to at least 80%. (Personally I fill to 100% and have never had a problem but some people will advise against this). Shock and diff oil is the same stuff but diff oil in general is a higher viscosity. You can also mix oils. I,E 50mls of 200wt and 50mls of 400wt will make 100mls of 300wt.
Old 01-14-2008 | 07:05 AM
thats cool thanks basically i purchased shock oil so it will be ok? will i have the same out come?
Old 01-14-2008 | 11:43 AM
Banned
ORIGINAL: GRANT ED
Do a search for diff oils and you'll find loads of info. Basically fill to at least 80%. (Personally I fill to 100% and have never had a problem but some people will advise against this). Shock and diff oil is the same stuff but diff oil in general is a LOWER viscosity. You can also mix oils. I,E 50mls of 200wt and 50mls of 400wt will make 100mls of 300wt.
Old 01-14-2008 | 11:50 AM
SManMTB's Avatar
ORIGINAL: Da Smak
ORIGINAL: GRANT ED
What?
Diff oils are in general HIGHER viscosity.
Old 01-14-2008 | 01:26 PM
Osirisf16's Avatar
Hey dude, he wrote higher already [&:]
However, yes the dif oils are "harder" than the shocks oils. Try something very thick for the center, something very thin in the rear and something inbeetween in the front
Old 01-14-2008 | 01:31 PM
ORIGINAL: scotty81
NO you will not have the same outcome diff oil is much thicker compared to shock oil. If you ran shock oil in your diffs it would have no benifical effect on the diffs other than a lubrication, you may as well just use grease it would at least be better than shock oil in the diffs. Next time you go to your LHS pick up a bottle of diff oil and shock oil and see how much thicker the diff oil is, the shock oil will be closer to water (not realy but its the best explanation I can give) the diff oil will be closer to thick honey. THe only similarity in the 2 types of oil's are they are both a silicone based oil. I think its silicone anyway.
Old 01-14-2008 | 01:59 PM
SManMTB's Avatar
It is silicone and it actually a pretty lousy lubricant too.
Old 01-14-2008 | 03:25 PM
Banned
ORIGINAL: Osirisf16
He did and he was wrong.
Old 01-14-2008 | 03:31 PM
SManMTB's Avatar
ORIGINAL: Da Smak
ORIGINAL: Osirisf16
[sm=confused.gif]
What's wrong with that? Diff oils are in general higher viscosity than shock oils.
Old 01-14-2008 | 03:35 PM
Osirisf16's Avatar
Dif oils are in general higher viscosity, end of the story. Don't continue this Also, a question guys, i know that kyosho has dif oils that have range up to 500,000. The other what maximum numbers have?
Old 01-14-2008 | 03:37 PM
ORIGINAL: GRANT ED
DaSmack: You better read it again. Diff oil IS generally HIGHER viscosity.
Old 01-14-2008 | 03:43 PM
Osirisf16's Avatar
Dif oils are much more "harder" than the shock oils. Is that more clear? Oh man, i'm starting to confuse. [&:]
