what engine do I have??
WI
OK I got this engine for free from the LHS(wich is closing)and have no clue as to what it is
the B is above the R
o ya its made in italy
http://s272.photobucket.com/albums/j...itrzac/engine/
RE: what engine do I have??
looks like a RexBR21SBk to me
scroll down its near the bottom on this page [link=http://cvrccc.esmartguy.com/Eng.html]HERE[/link]
Rex is just a rebranded Novarossi made by Novarossi but sold under the Rex name in some parts of the world due to contractual agreements
see also Top engines (same kinda deal)
the power output will depend if its a 3 or 5 port
see info for figures
you can also see the different novarossi engines on the main site [link=http://www.novarossi.com/content_uk/home/index.php]HERE[/link]
Manufacturer/Model Rex BR 21 B/BK Rex BR 21 SB/SBK
Size .21 .21
HP 2.0 2.2 hp
Bore 16.66 mm 16.66 mm
Stroke 16 mm 16 mm
Ports 3 5
Weight 331/340 g 335/350 g
Crank SG SG
Contstruction ABC ABC
Displacement 3.49 cc 3.5 cc
Type Off-Road Off-Road
Exhaust Rear Rear
Carb Slide Slide
RPM Range 28000 29,500
Pull Starter? No No
Description Older version had a green head but same specs. SBK Version: The intake chamber is small tank located inside the rear back cover. Linked by a silicone tube to the induction channel it gives a better fuel consumption.
Size .21 .21
HP 2.0 2.2 hp
Stroke 16 mm 16 mm
Ports 3 5
Crank SG SG
Exhaust Rear Rear
Carb Slide Slide
Pull Starter? No No
WI
ORIGINAL: sh0wtime
Size .21 .21
HP 2.0 2.2 hp
Stroke 16 mm 16 mm
Ports 3 5
Crank SG SG
Exhaust Rear Rear
Carb Slide Slide
Pull Starter? No No
Size .21 .21
HP 2.0 2.2 hp
Stroke 16 mm 16 mm
Ports 3 5
Crank SG SG
Exhaust Rear Rear
Carb Slide Slide
Pull Starter? No No
its the 5 port, any idea were to get a piston and sleve for it? also can any one sugest a CHEAP starter box from towerhobbies?
also the tube didn't come with it, is it ok to use fuel tubing or do I need a special kind?
any sugestions on carb settings?
dude its basically a Novarossi
any Novarossi dealer should be able to help you out, failing that have a nose through the engine specs on the novarossi site & order a liner/piston from an engine that has the same bore & stroke
WI
any sugestions on a cheap bump box?its a hyper 7
these were the ones I was looking at
http://www3.towerhobbies.com/cgi-bin...?&I=LXHUC7&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXCLD8&P=0
would this one work too?
http://www3.towerhobbies.com/cgi-bin...?&I=LXBN23&P=0
don't get a cheap one, you get what you pay for. I suggest a OFNA Chrome top or something like it. I have the 8ight bump box and it works just fine, but then again, i have an 8ight buggy
WI
The top one. Blue on the bottom and Chrome on top. I have one and it improved my RC experience 1000 percent. Don't forget the gell cell and the charger. It's not the cheapest, but you'll spend more time driving and less time trying to start the engine.
MI
WI
ORIGINAL: musclecar64
Actually, you probably should forget the gell cell. Skip it, and opt for a pair of standard stick packs. Lighter, more powerful, and overall just better.
I was going to do that anyway,
WI
Ok I think I will go with this one, does anyone know if a gell cell will fit in it or only stick packs?
http://www3.towerhobbies.com/cgi-bin...?&I=LXHUC7&P=7
ORIGINAL: Force4x4
Stick packs only last for a few starts and then need recharged, a gel cell lasts an extremely long time.
i race abroad quite a bit & the restrictions on baggage weight rule out a 12v gel cell [:'(]
if i had a really heavy starterbox i'd have to leave something at home & when you're away you need as much stuff with you as possible
TN
I have that box and if you really modified it, you could fit a 12v gell cell in it. But you would REALLY have to modify it, so I'd say no. Just because you would loose you option of running stick packs. Peace.
you could do what i do i use a 12v golf buggy battery in a carry case havent charged it in 6 months ish and i use it regulary.
WI
so has anyone had any problem with that box??
anyone try this one?
IN
This [link=http://www.amainhobbies.com/product_info.php/cPath/1_23_52/products_id/12542]box.[/link]
This [link=http://www.amainhobbies.com/product_info.php/products_id/16869]battery.[/link]
Scott
Scott
ON, CANADA
I use the OFNA truggy start box (10244) and two of [link=http://www.amainhobbies.com/product_info.php/cPath/1_221_224/products_id/20993]these [/link]. The batteries are cheap, but they last quite a while and start my nova N21 no problem. I would wait until you have a bitt more $$ to spend, you'll be glad you did.
WI
ORIGINAL: K-large
back on topic, these are the simalar engines but I cant find a place that sells the pistons and sleves
http://www.nitroreview.com/TheDataba...areengines.cfm
I decided to get this starter box
http://www3.towerhobbies.com/cgi-bin...?&I=LXCUC2&P=7
these batts
http://www3.towerhobbies.com/cgi-bin...?&I=LXTAR4&P=0
and this charger, it does LiPos for $54
http://www3.towerhobbies.com/cgi-bin...?&I=LXCTZ5&P=0
no I don't care about the low chargeing rate
The Chrome top box is great, you won't be dissapointed. Starts my Mamba no probs. Mind you I use a gel cell cos they really do last a long time.
Never tried with stick packs.
WI
back on topic, these are the simalar engines but, I cant find a place that sells the pistons and sleves
