RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
GRP .21 Tuned Engine
Old 07-24-2008 | 12:14 PM
Default GRP .21 Tuned Engine
With this engine I'm allowed to run 20% fuel right as long as I get the right plug for it and not use the turbo plug that comes with it?
Old 07-24-2008 | 12:37 PM
SManMTB's Avatar
Default RE: GRP .21 Tuned Engine
It'll run as is.
Old 07-24-2008 | 12:50 PM
As is meaning that I can run it with the turbo plug and 20% fuel?
Old 07-24-2008 | 12:53 PM
Yes
Old 07-24-2008 | 12:56 PM
Thanks alot.
Old 07-24-2008 | 02:20 PM
I reckon this engine is shimmed for 30% fuel and lot of people are using the OS P3 plugs.
Old 07-24-2008 | 10:38 PM
clifton421's Avatar
If the engine uses turbo plugs there are 2 things you must remember:
1) you cannot use regular plugs in an engine that uses turbo plugs without putting on a standard head button &
2) I don't think that engines that use turbo plugs use shims (please correct me if I am wrong on this one).
www.focusprinting.com
Old 07-24-2008 | 11:00 PM
musclecar64's Avatar
ORIGINAL: Focus Printing
Engines that use turbo plugs do use head shims, but no washer under the plug.
Old 07-24-2008 | 11:33 PM
Excuse me for being a little out of the loop on this being new to the sport but where do you put the shim?
Old 07-25-2008 | 04:06 AM
Nathan9492's Avatar
under the cooling head, they sit on the top of the crank case, and when u put the cooling head on, it sits on the shims, and thats how u get the clearance.
Old 07-25-2008 | 09:13 AM
Gotcha thanks a lot......... Got a question about engine I'm currently running, I have the hyper .21 race engine and it has a head shim on it, would I need to remove it due to the fact that I'm using 20% fuel and a MC8 plug because I have been having some serious problems trying to break this thing in?
Old 07-25-2008 | 12:30 PM
clifton421's Avatar
ORIGINAL: musclecar64
Thanks, I wasn't sure about that. I have never owned an engine that used turbo plugs
